2010 Saab 9-3 repair Question break bleeding
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONEYMATHEW
the break bleeding start from which side is it from front left or start from back side right for the all the vehicles we can use same procedure.
Jan 22, 2010 at 3:33 AM
RONEYMATHEW
[quote:0c6776d5c1="roneymathew"]Brakes problem
2010 Saab 9-3 repair Question 4 cyl Two Wheel Drive Automatic 90000 miles
the break bleeding start from which side is it from front left or start from back side right for the all the vehicles we can use same procedure.[/quote:0c6776d5c1]
Jan 22, 2010 at 3:44 AM
MNTHNY4
  • 612 POSTS
where did u get a 2010 saab from with 90'000 miles ,anyways to bleed saabs new models u start from LF then RR then RF & last LR ,THE OLDER SAAB bleed starting from RR wheel moving in a circler movement ,good luck .
Jan 22, 2010 at 7:09 AM
