2007 Saab 9-3 repair Question
2007 SAAB 9-3
40,000 MILES • 4 CYL • 2WD • MANUAL
VMJ
How do you change the low beam
Dec 29, 2009 at 3:33 AM
MNTHNY4
  • 612 POSTS
what type of bulb does your vehicle have ,is it xenon or is it the regular type bulb [H7]
Dec 29, 2009 at 12:10 PM
VMJ
It is the regular type bulb. However after further research we only needed to remove the washer fluid container with a slight twist and pull. this would allow clearance to reach inside the lights and remove the bulb.
Dec 30, 2009 at 4:08 AM
MNTHNY4
  • 612 POSTS
Ok good ,that's all there is to it simple .
Dec 30, 2009 at 11:37 AM
