2006 Saab 9-3 repair Question
LEIGHMORRIS
Engine Performance problem
2006 Saab 9-3 repair Question 4 cyl Two Wheel Drive Manual
I am in Wellingborough Northants. My problem is that approx. every third journey the car when I am in fourth or fifth gear experiences a power loss which the n rectifies itself when I drop down a gear and give it some oomph-the loss of power then returns when I change up again and this cariies on for around 5 minutes before going away completely. The whole thing is accompanied by a juddering similar to having a flat tyre.
My local non specialistb garage has put it on diagnostics and found nothing wrong-my local saab dealers have gone pop. Any ideas?
Sep 24, 2009 at 11:59 PM
MNTHNY4
  • 612 POSTS
hey what's up ,first things first ,is your vehicle check engine light on ,if not u may have a series of issue ,like a fuel pump going bad ,catalytic converter clogging up ,ecm software may need updating ,do not starting pulling car apart ,find a saab service garage ,problem could be simply to fix ,like just a software update
Sep 26, 2009 at 9:15 AM
