where is the yaw sensor on the saab,i do have a good manual but it i can not find it,if you don,t know say so and i look on a better site
Sep 26, 2009 at 9:37 AM
MNTHNY4
✓Experienced Mechanic
hey what's up ,as per location of your yaw rate sensor ,u will 1st have to remove gear shifter housing assembly it is located under housing bolted to floor ,there is no other way to get to it ,your saab 9-3 ss is set up like a lago toy mustly snap to fit after replacement u will need to use tech2 scan tool to add new unit to vehicle so best to let your local saab dealer install and perform programming ,good luck.
