2005 Saab 9-3 repair Question Drivers heated seat
2005 SAAB 9-3
BUDGIES974
Electrical problem
2005 Saab 9-3 repair Question Two Wheel Drive Manual 78000 miles
Hi the heated seat light comes on when pressed but switches off after 5 seconds and does not heat up, the passenger seat works fine, is there a fuse if so where would it be, or should I look for a heater element issue.
Many Thanks
Aug 28, 2010 at 7:53 AM
MNTHNY4
  • 612 POSTS
u need to replace the seat heating pad ,fuse is ok the problem is with the pad ,good luck.
Aug 29, 2010 at 10:12 AM
