2005 Saab 9-3 repair Question airbag replacement
2005 SAAB 9-3
DIMCHIK4672
Interior problem
2005 Saab 9-3 repair Question 4 cyl Front Wheel Drive Automatic
I am trying to take out my driver's side airbag for replacement with another one, but I cant seem to find screws or other ways of taking it off. It's not the same as the honda, nissan or toyota where the bolts are right there and easily accessible. So if you could look into it and let me know with some instructions on the way to take it off.
Jun 17, 2009 at 1:50 AM
MNTHNY4
  • 612 POSTS
u will need to set steering wheel straight ahead ,now to the left & right of the wheel fell foe a hole ,after locating hole turn steering wheel with hole up facing roof ,than with a small pocket type screw drive push in hole & pry forward ,pull up on that side of airbag module ,then do the same on the next side ,when release come up slowly & disconnect wiring .
Aug 29, 2009 at 1:35 PM
