2005 Saab 9-3 repair Question
BILLT47
on my 2005 9-3 the drivers door window ,mirror and doorlock will not work. i can jumper the window motor at the switch connector and the window will work. any help here/
Apr 20, 2009 at 6:25 AM
DAVE H
  • 13,383 POSTS
sounds like a wiring problem ... you should be able to power up the motor for the window .. also check the wiring loom where it goes through into the door for breaks in the wires !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_551.png
Apr 20, 2009 at 9:02 PM
BILLT47
thanks dave for the advice. i have checked all the wiring to and in the door and can find no problems there. as i stated before the window, mirror and door lock switches on the drivers door don't work. i can't see where they are tied together in any way. have jumpered the window motor and it runs ok. i don't have a wiring diagram so i can't traceit down that way. does anyone have any help out there?
Apr 21, 2009 at 11:13 PM
DAVE H
  • 13,383 POSTS
check fuse #15 in left side of dash fuse box .. will look at the wiring diagrams and get back to you !!
Apr 21, 2009 at 11:24 PM
