2004 Saab 9-3 repair Question HOOD, TRUNK, ETC.D
55,000 MILES • 4 CYL • FWD • AUTOMATIC
NIRVANA
sO MY CONVERTIBLE HOOD NO LONGER WORKS, I CANNOT GET THE TRUNK OPEN AND THE MESSAGE TELLS ME SOMETHING DIFFERENT CONSTANTLY. iT SAYS i HAVE A FLAT AND i DON'T. iT SAYS SOMETHING IS OBSTRUCTING THE HOOD - NOTHING THERE, NOTHING IN TRUNK ETC. I NOW CANNOT GET MY TRUNK OPEN AND THE DOORS LOCK ON OCCAISION WITH THE REMOTE. i AM HAVING A BREAKDOWN. HELP!
Jun 20, 2010 at 10:38 AM
MNTHNY4
  • 612 POSTS
sorry to say u need to take car to your dealer ,u have too many issue ,there is a code for each complaint u mentioned ,has for the flat tire u need to move the tires around & check if warning indication follows the position of the faulty wheel, if it does ,check air pressure,all wheels most have same pressure,note do air pressure correction before moving tires around ,u most drive vehicle at lease 2-3 miles to clear tire pressure warning system,after doing this if warning still present ,then start moving tires ,good luck .
Jul 26, 2010 at 2:02 PM
