2004 Saab 9-3 repair Question Chirping Noise
55,204 MILES • 6 CYL • FWD • AUTOMATIC
ROBERBOC
Help!
I have a 2004 Saab 9-3 Linear turbo with 55,000 miles. In the past 3 months it has started "chirping" for about 30 seconds when I back out of the garage in the morning with the a/c on. It does not chirp for the rest of the day, unless the car sits for at least 4 hours. It also ONLY makes this noise when I have the a/c on and put the car in reverse. If I leave it over night and put it in drive (or put in drive after it sits for a few hours) with the a/c on it does not make this noise. At first I was thinking it was the belt, so I just had that rpelaced and it still makes the noise.
Have you ever encountered a problem like this and any thoughts on what it could be?
Thanks for your help!
Rob
Aug 3, 2009 at 7:39 AM
MNTHNY4
  • 612 POSTS
cause your engine drive belt & tensioner assembly ,u need to replace them both
Aug 29, 2009 at 12:56 PM
