2003 Saab 9-3 repair Question Water Flooding
185,000 MILES • 4 CYL • FWD • MANUAL
SCHRENK
I want to start by commending your video on changing the breaks - it worked like a charm and saved my wife and I hundreds.
My current issue is from driving home during flash flooding. I couldn't tell the depth of a puddle and suddenly the engine quit. I would guess possibly 12 inches (basically high enough to not open the door). I pushed it out and back home. It sat for the night. The engine has not started since.
I think the battery is coincidentally going bad, but we have been draining the charge and periodically needing to bring it in to charge it (is there anything flood damage can do that can cause a short that will drain a sitting battery?). With a fully charged battery we can hear it trying to turn but just not firing. Once the battery drains we hear clicks.
I pulled out the air filter which was soaked and covered in leaves and debris. We cleaned the air filter area and put the filter in front of a fan to dry it out.
We parked the car on a slant with the front end elevated and water began trickling from the tailpipe. When we tried starting it, leaves and debris blew out the tailpipe and water began pouring. It didn't fire, but when we tried it a few more times we would get a steady water flow each time. The water drippage has ceased and now the starter just turns it over - but still doesn't fire.
My next step it to check out the spark plugs and coils, but I haven't tried it on a foreign car and I am afraid of what odd-ball tools Saab has strategically used to deter people from doing their own auto repair.
Do you have any recommendations?
Thanks,
Nathan
Nov 12, 2008 at 12:30 PM
MASTERTECHTIM
  • 4,750 POSTS
you wont need any special tools but you whould definitely start by removing the spark plugs and with the plugs out, crank engine over to get the rest of the water out of cylinders. install new spark plugs and say a prayer. water in the engine and attempting to crank can bend connecting rods and ruin engines. if it still wont start then i would suggest a compression test to see if the engine is internally damaged
Nov 12, 2008 at 12:46 PM
BMRFIXIT
  • 19,053 POSTS
This is what I would do
disable fuel system (remove fuel pump relay and or fuse)
remove spark plugs
crank engine few turns
so water exit the cylinders
do a complete tune up (plugs, wires, filters, cap ..)
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 12, 2008 at 12:50 PM
