2003 Saab 9-3 repair Question Trunk opens on its own
81,000 MILES • 4 CYL • FWD • AUTOMATIC
MICBOTT00
The trunk on my 03 saab 9-3 seems to open on its own. Its happend at least 4 times now, it will be parked in the garage overnight and in the morning i notice the trunk open. Naturally my battery is dead after being open all night. At first I thought i might be hitting the button on the keyless entry but after several times i know somthing else is causing this problem. Has any one had this problem or does anyone have some ideas? Thanks
Jul 3, 2008 at 9:35 AM
MNTHNY4
  • 612 POSTS
ha bro ,all saabs comes with a system when working correctly ,after 20 min turns of all electrical components & lights leaving only the alarm system function ,so in your case you have a wiring or a component that is not going to sleep after that 20min time frame ,you will need to check out the trunk lock motor & wiring ,good luck
Jul 19, 2008 at 11:48 AM
