2003 Saab 9-3 repair Question space saver spare
2003 SAAB 9-3
MIKE BERVOETS
Tires and Wheels problem
2003 Saab 9-3 repair Question 4 cyl Front Wheel Drive 33000 miles
I had a flat rear passenger tire. I changed it with the space saver spare tire. The wheel locked up and would not roll. I bought a new tire to replace the flat tire. When I put the full size tire tire on, it rolled fine. Is this normal? Why put a space saver tire in the trunk, when iy doesn't work?
If you could shed some light on my situation, I would be very appreciative. Thank you.
Jun 1, 2010 at 5:08 AM
MNTHNY4
  • 612 POSTS
FIRST OF ALL IS THIS THE RIGHT SPARE WHEEL FOR YOUR CAR DID U BUY CAR FROM NEW ,NEXT DID U CHECK IF U LOST A BRAKE CALIPER BOLT & CALIPER FIT CORRECTLY .WITH OUT MOVEMENT .
Jul 27, 2010 at 5:13 AM
