2003 Saab 9-3 repair Question removal of passenger side axle
LGENO
Drive Train Axles Bearings problem
2003 Saab 9-3 repair Question 4 cyl Front Wheel Drive Automatic
How is the axle shaft removed from the intermediate shaft. 2003 SAAB 9-3 SE. The manual I have makes it sound as if it can be pulled or prided out.
Dec 4, 2009 at 8:20 AM
MNTHNY4
  • 612 POSTS
u most first remove c-clip from support bearing in the middle section of the drive axle assembly ,then u will need to pry out ,that process is to remove complete assembly ,if u just need to remove axle section first remove inner joint boot clamp ,then just pull out ,& that is after u removed the out joint from the hub ,good luck .
Dec 4, 2009 at 11:32 PM
