2003 Saab 9-3 repair Question radio
2003 SAAB 9-3
60,000 MILES • 4 CYL • 2WD • MANUAL
PHILTIN
radio not working indicators no sound display blank
Feb 9, 2010 at 8:53 PM
MNTHNY4
  • 612 POSTS
u need a radio amp ,this amp is located under your drivers seat ,this amp has a fiberoptic wire going through it which inturn makes all those components u listed work ,u may have gotted the amp wet at some time ,or it just failed .so get a price from your dealer or check goldwing saab.com they will ship anywhere ,note used part for saabs only that is all they sell .good luck.
Feb 12, 2010 at 6:31 AM
MNTHNY4
  • 612 POSTS
ho also note that the radio head unit can cause the same iissues too ,to check all this take radio out & unplug connector from back ,now check if u can see a red laser light in the connector if u can then the amp is ok u can also do this at the amp under the seat too check for red light ,do this & post back & i can tell u for sure which component is bad .
Feb 12, 2010 at 6:37 AM
