2003 Saab 9-3 repair Question problem starting
35,500 MILES • 4 CYL • 2WD • AUTOMATIC
DIEMSAAB
my 2003 saab 9-3 randomly doesn't start and the computer would display TCS or traction control failure contact saab dealer. a foreign specialist mechanic replace the battery and abs module but problem persist.
it usually occur in the morning after cold night. Usually when it doesn't start, i would remove the key or clear the display panel and turn the ignition again and it would start. Any suggestions????
Feb 14, 2009 at 5:12 PM
SPLITTY
Same as my problem but mine doesn't start at all unless I remove a relay and bridge connectors in the UEC. Fault has been diagnosed as a faulty earth between Relay 7 and the control module (595B). Will hopefully be checking mine in to an independant auto electrician this weekend, will let you know the outcome.
Splitty
[quote:16d3631e52="Diemsaab"]Computer problem
2003 Saab 9-3 repair Question 4 cyl Two Wheel Drive Automatic 35500 miles
it usually occur in the morning after cold night. Usually when it doesn't start, i would remove the key or clear the display panel and turn the ignition again and it would start. Any suggestions????[/quote:16d3631e52]
Feb 16, 2009 at 7:31 AM
