2003 Saab 9-3 repair Question How to replace the fuel float.
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
MLOPERA
My car is a Saab 9-3 2003
When I fill the tannk, for some reason the fuel gage needle goes to Empty. After the gas gets used to about less then 3/4 tank, the needle marks the correct amount in the tank.
Am I having problems with the float in the gas tank?.
If that is the case, what are the steps to replace the float without taking the gas tank out.
Thanks,
Marco.
May 29, 2008 at 12:19 PM
MNTHNY4
  • 612 POSTS
cannot be done without dropping gas tank assemble will need to replace pump assemble
Jun 11, 2008 at 2:11 PM
