2003 Saab 9-3 repair Question headlight
60,760 MILES • 4 CYL • FWD • AUTOMATIC
AQUEENE10
I purchased this car in April '08. I had a problem with the left headlight so I took it to the Saab dealer and they replaced the bulb in Oct. I had the same problem in Nov, they replaced the bulb again. It happened in Dec as well. I figured at this point it must be something wrong with the wiring or the socket. Should I take it to a have it checked at an electrical place or just go to a mechanic?
Feb 21, 2009 at 1:07 PM
MNTHNY4
  • 612 POSTS
is your saab a 2003 sport sedan & is it the old body style 9-3 ,if it is the new body style you will need to replace the headlamp wiring harness ,there is is kit available for that fix ,it is normally the ground wiring inside the lamp that is connected to the bulb connecter that is burnt out which causes the problem ,check that .
Feb 22, 2009 at 3:03 AM
AQUEENE10
https://images.2carpros.com/forum/automotive_pictures/321422_217526944389_1.jpg
[img] I uploaded a pic. I don't know if it is an old body style. I will mention looking at the harness with whomever I get to take a look at the car. thanx
Feb 22, 2009 at 11:58 AM
KARENCAREN
  • 72 POSTS
Its better to replace to whole headlight rather than just changing the bulb. Just my 2 cents.
May 19, 2009 at 5:23 PM
