2003 Saab 9-3 repair Question Automatic Radio Antenna Replac
2003 SAAB 9-3
65,000 MILES • 4 CYL • 2WD • MANUAL
DSHERM
My electronic radio antenna's motor needs to be replaced at an estimated cost of $ 600.00. (The mast does not need replacement.)
I'd replace the antenna motor if I had any confidence at all that I wouldn't have to replace it again, but I do not.
I'm looking for a small, rubberized replacement antenna that will be effective in functionally picking-up FM stations.
Two questions:
1) Can you recommend a rubberized replacement antenna?
2) Can you recommend an installer in the Greater Ft. Lauderdale, FL area?
Thanks for your help.
Mar 14, 2010 at 11:39 AM
DSHERM
[quote:f65ecfac8c="dsherm@comcast.net"]Electrical problem
2003 Saab 9-3 repair Question 4 cyl Two Wheel Drive Manual 65000 miles
Two questions:
Thanks for your help.[/quote:f65ecfac8c]
Mar 14, 2010 at 11:41 AM
CHOLLACAT
Hi, dsherm,
I don't have an answer but I have the same problem and would like to hear what answers you receive. I have asked the same question on the saab3 yahoo group.
chollacat
chollacat@yahoo.com
Mar 18, 2010 at 9:46 AM
