i purchased a 2002 saab from a dealer as is. Car was smoking excessively with no turb boost apparent. i cleaned the oil pan and upper inside of engine to remove sludge some but not alot present. I replaced old turbo with a new factory turbo. everything looked good and the car ran great for about 3000 miles. it now has little boost again and is smoking badly when it does boost and I back off. Sound like a bad turbo again, but I am not going to throw the money away if there is another issue I should be looking at? A turbo should last more than 3000 miles. The car started going into "limp mode" out of nowwhere about 3weeks ago, the idle will drop to about 500rpms and I have to dis connect battery terminal to restore idle. a code was set p1251 but my parts shop could not decode the number for me. Could all of this be related?
Oct 29, 2010 at 2:14 AM
