2002 Saab 9-3 repair Question Not sure what the problem is
2002 SAAB 9-3
86,000 MILES • 4 CYL • 2WD • AUTOMATIC
BARBARA1
Hi! Do I have a question for you. My local mechanic is stumped. Occasionally when I start my car, and it starts fine. The alarm lights go off but Within 60 seconds all of the alarm lights come on again. the ABS, the Traction control. If I turn off the igition and restart the car they all go off. This may happen 4 consecutive times or it might happen 4 times out of 60 starts. Additionally, now the thermostat needle sometimes drops to the lowest point but if I turn the car off and restart it comes back to normal. I don't know if this is an electrical problem, a sensor gone bad or what? Any ideas?
Sep 6, 2008 at 3:45 AM
BMRFIXIT
  • 19,053 POSTS
Testing need to be done
I would suspect an electric problem
start by checking the ignition switch
separate car key from all other s if any
good luck
Sep 6, 2008 at 11:42 PM
