2002 Saab 9-3 repair Question mis-fire
2002 SAAB 9-3
86,000 MILES • 4 CYL • FWD • MANUAL
THUETHER
The 2.0 liter turbo charged engine is great overall (great gas mileage, and great power), but my engine light came on and I now have mis-firing from the engine when first started, and sometimes when idling. I have changed the spark plugs with NGK platinum plugs. Any ideas?
Sep 20, 2009 at 6:37 AM
MNTHNY4
  • 612 POSTS
hey what's up ,as per your mis-fire issue ,u will need to read codes from system ,but anyways u may have a direct ignition cassette fault ,that is the part that sit on top of the spark plugs ,so if the codes u read r p1334,p1312 or p0340,then that is related to your DI CASSETTE ,if non of those code present then u will need to get injector flushed or clean ,those r the only 2 issues for mis-firing with that car
Sep 26, 2009 at 10:08 AM
THUETHER
Thanks, you guys are the best.
I will take your advice and start there.
Sep 27, 2009 at 9:18 AM
MNTHNY4
  • 612 POSTS
you r welcome ,if info help to fix your issue state which ,may be helpfull to others in the future with same type issue .
Sep 28, 2009 at 2:37 PM
