2001 Saab 9-3 repair Question Like a fan noises
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
BULENT
Hi i have a 2001 saab 9-3,4 cyl,2.0 engine.
Before i change my air filter there is a noise comming from next to the cigarette lighter. Even i turn off my engine it still continuous about 7-9 minutes than stops. After i changed my air filter noise got worst. it is doing the same thing with worst noise . I assume that it is connected with the air filter. What do you thing could be a problem.
Thank you very much .
Mar 26, 2010 at 7:20 AM
MNTHNY4
  • 612 POSTS
U NEED A INTERIOR TEMP SENSOR , THAT VENT LOOKING THING NEXT TO WHERE YOUR SEAT HEATER SWITCH WOULD BE LOCATED ,U HAVE TO REMOVE ACC CONTROL PANEL TO REPLACE IT POPS OUT FROM BEHIND ,GOOD LUCK .
Mar 30, 2010 at 12:57 AM
