2001 Saab 9-3 repair Question
2001 SAAB 9-3
MERADHUR
Interior problem
2001 Saab 9-3 repair Question 74000 miles
The dashboard warning light of the carsihoutte with the red triangle below keeps flashing on, especially when I go over bumps. I just bought the car used and do not have a manual. What does it mean? Thank you
Apr 17, 2008 at 11:52 PM
IRISHMOBILEMECHANIC
  • 10 POSTS
hello, im assuming when you say "flashing on" that you mean intermittently appearing on dash,this is almost certainly fluid levels,firstly check oil via dipstick ensure level is within permissable levels,then check brake fluid(most likely to be this) look at the bottle its clear(ish)there is a mark on it ,max and min ensure its at the max mark,check coolant via expansion bottle,check power steering fluid, this will amost certainly solve your problem
regards irishmobilemechanic
May 1, 2008 at 10:40 AM
