2000 Saab 9-3 repair Question Starting issues
61,000 MILES • 4 CYL • FWD • AUTOMATIC
RSAAB
Several times over the past two month period the car has refused to start (nothing when key is turned) go back later and car starts. The last time car was towed by mechanic who checked it the next day and it started. Can't pinpoint issue, doesn't even respond to jumping off when it doesn't start. Battery appears fine and lights, etc, work but ignition doesn,t make any noise or attempt to turn motor over.
Nov 19, 2009 at 9:39 AM
  • 75,988 POSTS
Possible causes could be the ignition switch, park/neutral switch, starter relay and the starter itself
Nov 19, 2009 at 10:17 AM
MNTHNY4
  • 612 POSTS
just replace your neutral position sensor ,[or trans range switch ] located on top of transmission under battery ,gear shifter cable is connected to it .
Nov 20, 2009 at 3:27 AM
