Engine Mechanical problem
2000 Saab 9-3 repair Question 6 cyl Front Wheel Drive Manual 106K miles
I have a tiny oil drip. When I crawl under the car I see a drop from the oil drain plug. I recently had the oil changed and checked to make sure the plug was tight. It was. I took it back to the shop and the guy said the drip is coming from the PCV Valve directly above the oil plug and needs to be replaced. My question: Does this make sense? Can I easily replace the valve myself...if I can find it?
Oct 2, 2009 at 4:01 AM
