2000 SAAB 9-3 repair Question Ignition
GEBTHOMAS76
  • 2000 SAAB 9-3
Computer problem
2000 Saab 9-3 repair Question 4 cyl Front Wheel Drive Automatic
We are having problems with what seems like the ignition. The car starts fine when it is cold. After you get to your destination and then try to restart the car after a few minutes, it will not start. If you let it sit for about 15 or 20 minutes it will then start.
Sunday, August 9th, 2009 AT 8:14 AM
DOCFIXIT
  • 18,828 POSTS
Hi
The no start does starter not operate or it does but engine won't fire up and run?
Let me know
Monday, August 10th, 2009 AT 10:55 AM
MNTHNY4
  • 612 POSTS
U will need to replace crankshaft position sensor, if starter motor turns eng over, if no crank then u will need a trnasmission range switch, section that shifter cable is connected to ontop of transmission
Tuesday, October 6th, 2009 AT 12:59 PM
