Engine Performance problem
2000 Saab 9-3 repair Question 6 cyl Front Wheel Drive Automatic 87K miles
Check engine light on about 75% of starts. OBD says fuel injector shorts on cyl 1/2. Since the light doesn't always come on, do you think this problem only startup? Car is at 87K (just had oil changed) and want to get to 90K routine maintenance before I take it in. Do you think this fuel injector short will cause the car to go into limp mode before then? Are then any negative ramifications about driving it until then? Thanks.
Sep 9, 2009 at 4:24 AM
