2000 Saab 9-3 repair Question ABS Control Unit
13,000 MILES • 4 CYL • FWD • AUTOMATIC
TORI911
The dashboard icons ABS, exclamation point in a triangle, etc. are lit up sometimes for days and then off at times for days. Could there be a poor connection, short, or something loose? My mechanic told me it the unit needed replacement and that it was very costly. (approx. $2k including labor)
Jun 10, 2010 at 3:20 AM
DAVE H
  • 13,383 POSTS
Hello ... thanks for the donation .. much appreciated We would need the fault codes to give a diagnosis of the fault .. have the codes read by autozone or aamco next time the light is on and repost with full codes for more information .. it is very unusual for an ABS unit to have an intermittent fault it could be just a sensor or wire/connector .. usually when a control unit/module is bad the light stays on all the time ! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1156.png
Jun 10, 2010 at 8:58 PM
