2000 Saab 9-3 repair Question
EUGCHELSEA1
How do I replace the wing mirror assembly on the door? The old one is smashed and still attached to the car, I have a whole new assembly ready to fit
Jan 18, 2009 at 10:14 PM
WAHASKELL2
  • 7 POSTS
if what you want to know is to replace the mirror on the door then its not to bad,all you need to do is open your door and look at the triangular piece where you adjust the mirror (up,down,left,right)on the drivers side (passengers side is the same). you will see two round plastic circle pieces with a little round pin in the middle that you push down and then you can pop the round plug type piece out ,therefore the plastic cover will easily come off and you can disconnect any wires and set aside and you will see (3) torx or star srews that must be removed and then the mirror will come right off without any problems and then just replace in the opposite order(if you look the car comes with the correct size torx srewdriver in the spare tire compartment)
Good luck,wahaskell2
Jan 26, 2009 at 11:56 AM
