1999 Saab 9-3 repair Question Starter
147,000 MILES • 4 CYL • FWD • AUTOMATIC
PMYATT
On my SAAB the solenoid is engaging but the starter is loosing 4 volts while trying to engage and it wont turn over. Battery & cables are good. 12.20 volts at battery terminals and at starter terminals until the load is placed and it looses about 4 volts and only the solenoid engages. Is there a relay for the starter on this model? I cannot find it as a part offered anywhere.
Jun 7, 2008 at 12:51 AM
  • 75,988 POSTS
I don't consider this battery good-it has to have 12.4 or better- If it can hold 9.6 volts when you crank engine over for 10secs while ignition system is disable -its good if not replace the battery then go from there.
Jun 7, 2008 at 12:56 AM
