1999 Saab 9-3 repair Question Headlights not working
170,000 MILES • 4 CYL • 2WD • MANUAL
ROBDIGHTMAN
I replace both head lamps because they were out and the new ones don't work either. I checked the fuses and they look good. I replace the low beam relay and they still don't work. The passenger side high beam is the only light that is working. What should I check next?
Jan 30, 2010 at 8:33 AM
MNTHNY4
  • 612 POSTS
u need a headlamp control relay ,that is the orange colour relay in the engine bay fuse box , turn your high beam on if u do not see the blue high beam indicator in the dash ,just go outside now & move said orange relay side to side u should now see other high beam light come on & dash indicator on ,so replace the relay & u r good to go ,but bare in mind this relay new is almost $200 ,so go check your junk yard for a couple ,good luck.
Feb 1, 2010 at 2:33 AM
