1999 Saab 9-3 repair Question Fuel pump
1999 SAAB 9-3
70,000 MILES • 4 CYL • FWD • AUTOMATIC
MTWITE
how do I change the fuel pump?
Thanks
Apr 22, 2009 at 5:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove fuel tank (as described below). Use special tool 83 94 462 (contact local dealer or tool supplier) screw ring removal tool to unbolt fuel pump retaining ring. Lift fuel pump up about 2", then turn clockwise 80 degrees. Carefully remove fuel pump. To reinstall, fit new "O" ring in tank mounting groove. Check alignment marks between fuel pump and tank. Reverse removal procedure. FUEL TANK REMOVAL/INSTALLATION
https://images.2carpros.com/forum/automotive_pictures/261618_ft_1.jpg
Thanks for using 2CarPros.com!
Apr 22, 2009 at 6:05 AM
