1999 Saab 9-3 repair Question Convertiable top problems not
130,000 MILES • 4 CYL • 2WD • MANUAL
TRACYMUSIC77
The top on the saab is not wanting to go up and down all the way.
Feb 20, 2009 at 10:59 AM
MNTHNY4
  • 612 POSTS
check your hydraulic fluid level from pip hole inside trunk ,if oil level is ok than check if your 5th bow intermediate switch arm is bent ,switch is on the d/s side up in the corner where the tonneau flap would sit ,top must be open part way or all the way to see switch up in corner ,check that and get back to us .
Feb 22, 2009 at 2:53 AM
