check your hydraulic fluid level from pip hole inside trunk ,if oil level is ok than check if your 5th bow intermediate switch arm is bent ,switch is on the d/s side up in the corner where the tonneau flap would sit ,top must be open part way or all the way to see switch up in corner ,check that and get back to us .
Feb 22, 2009 at 2:53 AM
