1999 Saab 9-3 repair Question Clutch is stuck
116,000 MILES • 4 CYL • FWD • MANUAL
KATTRASK
  • 8 POSTS
I bought this car yesterday from an individual. I was assured that the clutch was brand new. The master cylinder was replaced less than a month ago. All leakes etc, had been repaired.
I did not make it home before the clutch pedal stucjk the the floor and the clutch would not engage. I had it towed to the company that fixed it, and they say it is not the master cylinder (which is under warranty) but another leak.
I think these guys do not know what they are doing. They have worked on this car twice, charged over $800 and it is acting exactly the same as it idid before they ever touched it. What I want to know is if I add clutch fluid, can i drive it to a different shop safely? are there more than one type of clutch/transmission fluids on this car?
Jun 10, 2008 at 3:17 AM
MNTHNY4
  • 612 POSTS
clutch fluid as per saabs is the same as the brake fluid ,which inturn the clutch master cylinder is feed via the brake master cylinder check clutch hydraulic high pressure line on d/s just above gearbox assemble ,if as u say the clutch,pressure plate are new
Jun 11, 2008 at 1:41 PM
