1999 Saab 9-3 repair Question Brakes squeak
84,000 MILES • 4 CYL • FWD • AUTOMATIC
RAFY210
The breaks squeak when I first apply normal braking but go away as I continue to hold the breaks. I do not know if its the master cylinder or the front or rear break that produce the noise. What could this noise be? [img:66af704c9a]http://www.2carpros.com/forum/automotive_pictures/553788_saab_wheel_1.jpg[/img:66af704c9a]
Jul 23, 2010 at 2:05 PM
  • 75,988 POSTS
Brake squeal is a symptom of the vibration generated by the brake pad contacting with the rotor and the caliper.
Try replacing the brake pads and go from the there-brake rotors might need resurfacing
Jul 23, 2010 at 8:25 PM
