S light flashes
261,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
REZA MAHOMED
Hi, my car does not drive in auto i have to manually shift gears. when in D the car is limp and the S light on the dash flashes which is the transmission light . Any solutions to this issue?
Apr 6, 2018 at 10:08 AM
  • 31,937 POSTS
You first need to run a diagnostic code test and record any codes and post them here for evaluation and further advice. the light is indicating that a fault code has been set.
Apr 8, 2018 at 6:34 AM
