Rythmic Changing of RPMs when stopped and braking
160,000 MILES • 4 CYL • 4WD • MANUAL
MILLELIJ
So my truck has been having an issue with this for a while, however sometimes it goes away and then sometimes it's there. The problem initially is that when I would come to a stop and only when the brake was pushed in the engine would rhythmically change rpms (fast, slow, fast slow) but when I whole take my foot off it would stop and the engine would idle normally. However recently it's gotten worse and the rhythmic pulsing of the engine now happens at a higher rate and when the brake is pushed in and also now when the brake isn't pushed in but a at a slower rate.
Thanks, Eli
Sep 22, 2014 at 3:35 AM
KHLOW2008
  • 41,812 POSTS
You have a vacuum leak and it seems to be coming from the brake booster. Most likely the braking efficiency of the vehicle is not too good.
Sep 22, 2014 at 3:37 AM
