Rusted truck bed inside by wheel wells
2004 FORD F-150
228,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
PPRINCE72
  • 58 POSTS
I'm looking for a aftermarket repair panel that fits on each side in the bed that can be welded, glued, riveted to the floor with the floor ribs in it. Any help is appreciated. Thanks, Phil
Jul 16, 2020 at 10:57 AM
  • 110,244 POSTS
Hi, Phil.
Unfortunately, we don't supply body repair components. However, if you look online for aftermarket truck bed replacement parts, you should be able to find something.
In the past, I have even seen people cut a good section from a damaged bed and weld them in. It's just a thought.
I wish I could be of more help. Let me know if there is something related I can help with.
Jul 16, 2020 at 11:16 AM
STEVE W.
  • 15,351 POSTS
I looked at the companies I normally use for sheet metal, Raybuck, Sherman, AMD, Dynacorn, Mill Supply and none of them list bed repair panels for a Ford F-150 as new as that. However Mill Supply does show a few Ford bed patch panels for older trucks. You might want to make a measurement of the bed ribs you have for height, width and spacing and give them a call and see if one of the panels they sell might fit with some work.
800-888-5072
Jul 16, 2020 at 4:38 PM
