Runs when pushed and clutch popped but will not turn over with key
BOLIVER1
  • 1992 FORD F-250
  • V8
  • 4WD
  • MANUAL
  • 150,000 MILES
Left accessory on, ran battery down. Charged battery and then replaced, also replaced starter and solenoid on fender well. Will not crank, only click. Will run if pushed and clutch popped. Help!
Monday, October 16th, 2017 AT 4:52 PM
  • 31,937 POSTS
By pass the clutch pedal switch and see if this stops the problem, there will be a switch at the top of the clutch pedal. Check for twelve volts at the starter solenoid switch and main solenoid wires to starter are clean and tight. If okay, and solenoid is switching check starter.
Monday, October 16th, 2017 AT 6:32 PM
