Will not stay running, check engine and check gauges lights turn on
66,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MELLIHUGHES
Car will start and run on its own for about 3 minutes then stalls out and won't restart until it has sit for about an hour. The check engine light and check gauges light both come on at the same time. It will also run rich when it is driven.
Jul 15, 2021 at 1:15 AM
SQM
  • 6,383 POSTS
Have you check for the codes on your vehicle?
https://youtu.be/vMwTzURWXmk
There are few items for this to happen. It could be a faulty coolant temperature sensor, could even be a crank sensor.
Here is a helpful article:
https://www.2carpros.com/articles/stall-at-idle
Let me know what you find on the codes.
Jul 15, 2021 at 1:24 AM
