Runs The SAME With TPS Unpluged
1995 TOYOTA 4RUNNER
325,000 MILES
CLEVERLION2U
Having sporadic idle - 900 1 minute & 1100 the next - with NO power off the line until 15 MPH, I've cleaned injectors, found no vacuum leaks & installed new plugs. Still runs the same, so my next thought is the Throttle Position Sensor. SOooooo, I unplugged the TPS and engine runs the exact same. More ideas anyone ???
Thanks for your time & Feedback,
Michael
Apr 21, 2013 at 4:36 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides with choke cleaner and iac hole first see if that clears it up
Apr 21, 2013 at 6:12 AM
