I have a 1973 xa ford falcon starts up good with the choke on when warm and I take choke off idles up and down isn't a consistant idle can you help
May 9, 2014 at 10:47 AM
✓Experienced Mechanic
Have you checked for vacuum leaks? Does it have a manual or automatic choke?
May 9, 2014 at 12:04 PM
KEVOO71
MEMBER
doesn't appear to be any vaccum leaks manual choke
May 9, 2014 at 4:08 PM
Can you confirm the model year as a 1974? I don't believe they were made then.
May 10, 2014 at 8:51 AM
KEVOO71
MEMBER
1973
May 10, 2014 at 10:23 AM
Okay... does it have a points and condenser ignition system?
May 10, 2014 at 11:36 AM
KEVOO71
MEMBER
yes it does
May 10, 2014 at 12:26 PM
Check the points. I have seen the spring on them get weak and as a result, the timing would change. Also, check the throttle plate for play. The rod that holds it may be worn and causing a leak.
May 11, 2014 at 5:53 AM
KEVOO71
MEMBER
checked them they are ok but have a constant idle now adjusted mixture and throttle screw now I have a dead spot just as I start to push down on the pedal its fine then I get a dead spot sort of goes to die and then revs maybe when I put air cleaner on and take it for a run it mite sort it fingers crossed
May 11, 2014 at 6:40 AM
Chances are it still needs some fine tuning with the air / fuel mixture. You may want to try that if there is still a dead spot. Also, make sure the accelerator pump is working properly.
