runs rough, no idle
143,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ALLEN NELSON2
hard to start, runs rough when it dose run and it will not idle at all. smokes black suit like smoke when running. Any suggestions on the issue I am having here?
Jan 20, 2018 at 1:52 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The black smoke is a sign that it is burning too much gasoline. Check the fuel pressure, if it is too high, over 13 psi that could explain it and if it is check for a kink in the metal fuel line causing excessive back pressure and if none is found try replacing the fuel pressure regulator located on the throttle body. If the fuel pressure is okay, you may have one or both fuel injectors dripping gasoline, so remove the air cleaner and look at the spray patterns while the engine is idling. If it will not idle, have someone else keep there foot down slightly on the gas pedal. Then look for any dripping in either of the fuel injector spray patterns, if found either try some fuel injector cleaning or replace the dripping fuel injector. Make sure neither drip when the engine is off, too.
Jan 20, 2018 at 9:56 PM
