Runs rough in reverse and in park
75,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CHEEVA2006
Just started after having no previous issues. Recent tune up. It misfires/runs rough in reverse and when put in park. In drive it runs perfectly fine. Any ideas?
Mar 21, 2019 at 2:12 PM
JOETECHPRO
  • 705 POSTS
Hey CHEEVA2006,
Have you got access to a scanner?
If so please scan for codes and let us know what you have.
If you have no misfire codes please carry out a power balance test.
When selecting P,N,R and D what happens to the power balance?
Do you also get the roughness in Neutral?
Do you get a reduction in power from any cylinders?
From what you have said it sounds more likely to be a motor/transmission mount issue than a misfire.
If you have no PCM codes and the power balance checks out ok i would say check for a bad motor/ transmission mount.
Any more questions don't hesitate to ask.
Let us know how you get on.
Regards, Joe
Mar 23, 2019 at 5:41 AM
