2002 Chevy Malibu runs rough
95,248 MILES • 6 CYL • FWD • AUTOMATIC
RAYRAY
my car runs rough. And white smoke is coming out of the tail pipe. It runs rough when climbing a hill. I had the cat replaced. the check engine light is not on. i did a tune up but no change, i also replace the fuel filter some change but then it runs rough again. it seems to be using a lot of fuel.
Jan 6, 2008 at 12:23 PM
BMRFIXIT
  • 19,053 POSTS
[quote:bd97aa88ab="rayray"]Engine problem
2002 Chevy Malibu 6 cyl Front Wheel Drive Automatic 95248 miles
my car runs rough. And white smoke is coming out of the tail pipe. It runs rough when climbing a hill. I had the cat replaced. the check engine light is not on. i did a tune up but no change, i also replace the fuel filter some change but then it runs rough again. it seems to be using a lot of fuel.[/quote:bd97aa88ab]
are you loosing coolant is the car over heating
do a head gasket test
they have a kit that you can use for that test
Jan 7, 2008 at 11:41 AM
