I believe my car may be an SL2, but not sure. Just recently I was driving and the engine made a weird noise then stalled out. At first it would not restart, but after letting it sit for a little bit it started but sounded really rough. After letting the car sit for about thirty minutes the car started at a slightly higher idle than normal, but it did not sound rough anymore. When I attempted to put it in gear the car started running really rough and as soon as I hit the gas, it stalled. It would not engage in any gear and would only idle in park. (did not try to idle it in neutral) After waiting for the tow truck and having the car towed home, the car started right up, had a little bit of a high idle, but it started. I placed it in gear and it ran perfectly fine. The next day I drove it to the store, it ran fine. When I came out from the store and started the car up it had the high idle and as soon as I put it in gear, it ran real rough again, this time when I hit the gas it did not stall out but it was running so rough that I did not feel comfortable driving it. Again waited for the tow and after getting it home, it started right up and I was able to drive it around the yard.
Any ideas of what this sounds like?
A bad transmission sensor or some kind, part of the power pack failing? anything else?
Please help.
Please help.
Sep 17, 2017 at 1:39 AM
