Code P0135, runs rough?
110,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
CLINT JANES
  • 5 POSTS
My vehicle runs really rough. I originally thought it was the O2 sensors, so I took it to a shop and spent $1,500.00 for sensors, spark plugs, fuel pump, and injectors just to get it back and it runs no different than when I dropped it off. I put a new crank position sensor on it myself and that didn’t help at all either. It hasn’t thrown a code at all till last night and it gave me a P0135 code. I’m out of ideas. Any suggestions?
Oct 3, 2022 at 12:10 AM
  • 55,740 POSTS
The code P0135 is O2 sensor heater circuit bank 1 sensor 1. so, that will not make the engine run rough, but you do need to replace the sensor. Are there no other codes? If not, we need to do a compression test, while you have the spark plugs out look at their condition the spark plugs that look different will be the cylinder that is having the problem. here is a guide to help you with the job, you can rent the gauge from the auto parts store for cheap or free. You can just upload a short video of the engine cranking over and I can tell if the compression is okay as well.
Let us know what happens and please upload pictures or videos of the problem.
Oct 3, 2022 at 9:01 AM
CLINT JANES
  • 5 POSTS
Ken L. No other codes at all. I did already did a compression test and every cylinder read 150. I pulled the plugs and replaced all of them with new double platinum's. I drove it a couple of miles and pulled them again and cylinders 2 and 3 were very black.
Oct 4, 2022 at 2:08 AM
  • 55,740 POSTS
Nice work, I would replace the #2- and #3-cylinders fuel injectors.
Here is a generic guide to show you how with instructions below to show you on your car:
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Check out the images (below). Please let us know what happens. Don't forget to replace the oxygen sensor.
Oct 4, 2022 at 8:57 AM
CLINT JANES
  • 5 POSTS
I should have mentioned it, but I already changed the injectors also. Is it possible to have a weak spark off the ignition coil? I have spark on every plug, but I’ve had a couple of people tell me it can have a weak spark.
Oct 5, 2022 at 2:24 AM
  • 55,740 POSTS
Yes, definitely a weak spark can cause the problem.
Oct 6, 2022 at 3:53 AM
CLINT JANES
  • 5 POSTS
with all the stuff I’ve changed already, would an ignition coil be what you tried next?
Oct 6, 2022 at 6:01 AM
  • 55,740 POSTS
Yep, that is where I was going next here is how you can change out the ignition coils in the images below. Check out the images (below). Please let us know what you find.
Oct 7, 2022 at 8:25 AM
CLINT JANES
  • 5 POSTS
It was the ignition coil causing the problem. Thank you so much for your time. I really appreciate it.
Oct 7, 2022 at 1:31 PM
  • 55,740 POSTS
Good to hear, please use 2CarPros anytime we are here to help. Thanks for getting back to us.
Oct 8, 2022 at 3:02 AM
