Runs rough and bogs down when when accelerating
200,000 MILES • 5.2L • V8 • 4WD
BIG ROBERT
Engine bogs down when when I accelerate. About at 45 mph . Then after engine warms up it stops . This is mainly in summer time. I had new plugs,wires and distributor cap . Plus new fuel pump . In last year . Could it be the TPS , air idle control MAP sensor or even clogged catalytic converter? I just don't want to spend good money . Any suggestions?? I am pretty good on trouble shooting.
Aug 20, 2020 at 1:29 AM
Good morning,
I would check the fuel pressure to be sure it is correct.
I would also check the back pressure on the cat converters to be sure they are not blocked.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/engine-hesitates
Aug 20, 2020 at 1:57 AM
BIG ROBERT
I will look into these options. Thank you gentlemen for such a quick response!! I will post my findings in a week.
Aug 20, 2020 at 2:18 AM
You are welcome.
Keep us updated.
Always glad to help.
Aug 20, 2020 at 2:19 AM
