Runs rough
108,630 MILES • 2.2L • 4 CYL • AWD • AUTOMATIC
KATHY DAVID
I had my oxygen sensor changed and check engine light shut off it came back on within 7 miles from garage. Engine runs rough and check engine light flashes when running rough then comes out of it when I get behind another car and have to slow down it goes into running rough like I have lost power
Jan 12, 2016 at 10:39 AM
PACO8224
  • 117 POSTS
You need to check for engine codes with a obd2 scanner, your vehicle is missing and it should tell you what cylinder it is.
Jan 12, 2016 at 10:47 AM
PACO8224
  • 117 POSTS
Every time engine light flashes its telling you that engine is misfiring
Jan 12, 2016 at 10:48 AM
